Click on the button with the three lines and go down to log out of app. What's selected there?
Not sure I understand by "What's selected there". When I select the button with the 3 lines and scroll to the bottom, there's an EXIT option but when you click that it takes you back to the home screen of the box.
It does show v1.5 (72) at the bottom of that menu. The update that was pushed to the box today didn't resolve the issue. My stream stops quite frequently and the error message that comes up on the screen states "Stream is not available. Try again later". I'm not convinced this is a server issue since as soon as I hit the OK button, the stream immediately starts up again with no delay. It's definitely not a connection issue on my end as I have a very strong ethernet connection.
Any ideas/suggestions?
I had that message today watching a baseball game on channel 432 ( Stream is not available ) but could not get the picture back.....other channels at the time were working fine.I believe that channel stopped working because of the service.......Have a Dreamlink T1 in the garage..........And could not get that channel to work either.....Yet the night before watching the same channel on the Buzztv box.and it worked fine for the whole 3 hours of the ball game...with not even a slight hickup.........So I doubt it was the box causing the problem..........I'm using NFPS service
Wow I myself don't get those problems.
I accept the update then I did a hard reboot of the box and mine working good.
However I am on a different server than what's supported here.
Look in the support forums for iptv to see if there is any problems with the service offered here.
As myself I don't experience what you's are experiencing.
Has the EPG issues regarding the time been fixed?
Don't think I ever said I owned one.... How much do they cost and where can I buy them from?
LOL..... some of the guys are saying there are still some existing issues that haven't been fixed with the latest update. So one would be hesitant to update their box with this, so the issue with the EPG was a big one that we all wanted fixed.
