"david_avov" and your location sells me a lot. Need to hear from outsider. No offence.
Make sure you take a look at the hardware requirements for each game before you boot it up. Each game tells you what kind of device you need to play the game in its description, for example [Gamepad] or Note: needs something. I believe the Minecraft game needs a gyro remote or mouse to play so you will want to look into setting that up. I realized we don't have easily accessible support for it so I'm talking with the technical team about releasing some sort of gyro remote for your phone. We have it developed already but for some reason have not released it. Keep an eye on our documents page for a download for it. I will likely make a post in the games section when that becomes available.
you are right on that one maybe try a usb kb with mouse i dont know will try later
Yeah it doesn't unfortunately. I don't know why it wasn't integrated with the controller (i'm sure there was some reason behind it) but the controller doesn't work for it. We should come up with a release for some sort of virtual remote on your smart phones some time soon so that you wouldn't have to worry about it. But for now no, sorry
The best I can do is push the technical adviser to come out with support for this. I'll be honest and say the following weeks are going to be really busy as we have some very important content we are developing. It will end up on the wishlist and hopefully gets implemented sometime soon. Unfortunately you will have to either work with whatever tools it says to play with or play on a different platform. I'm sure at one point it will be up there.
