I can make up a favourites by pressing blue button and making them up on my Dreamlink T1 Plus IPTV Set Top Box Smart TV
when I switch it off and back on again, favourites are missing.
any help will be appreciated 👍 Thanks
Are all of your favs missing when you start back up?
Captainkangaroo has explained that favourites are stored on the server, not the Dreamlink. Some servers have a glitch that they will only save favourites once. Meaning if you add a favs list, then add more channels on another day, only the new channels will be saved, not the original channels, on startup.
If that's what is happening to you, there is your explanation. If you are losing all your favs on startup every time you save them, that is a new problem and maybe someone server side can help you.
I have the same problem . Either they are missing or I only see the last ones I recently added. Say i have channel 20 to 30. i add chanels 1 to 20 on next startup I only see 1 to 20. How can this be fixed?
