I see that many of the uk channels are cutting out after 1 or 2 minutes is it just me?
Hi, it is not you alone. I noticed that as well. I am using a MAG 254. It was also happening on one US channel that I tried...Boomerang (174).
All channels across are experiencing the same problem even USA channels.
My mags boxes are pointing to the correct server I update the latest software dated April 5, reboot my router it does not help, I'm going to switch providers and try something new this is unreal
I am also starting to look for a more stable provider.
One that doesn't install an update that disables many of the Mag functions.
I have the highest internet avail and still there is freezing.
Could it be that they have been leaching off filmon, I have been checking the kodi filmon addon and it is doing the same thing.
After 2 minutes they cut you off filmon without a sub
all seems ok this morning on uk feeds so far.
Yes, it was much better when I checked. US channels were down, though.
