Results 11 to 20 of 25
    Pinball Wizard
    T1 plus Remote if you press back button it will take you back to the prior channel, you press the Exit button you it will ask you if you want to exit live channels. my findings
    Apr 2017
    Profster, are you using a harmony remote?
    Quote Originally Posted by jphccfc View Post
    Correct I am indeed using a Harmony Remote
    Apr 2017
    same here, exit button stopped working on my harmony after the update. resynced it and all good now.
    Quote Originally Posted by koushtj View Post
    What do you mean that you resynced it?
    Warrior
    Quote Originally Posted by profster View Post
    https://support.myharmony.com/en-us/harmony-fails-to-sync
    Apr 2017
    I ended up using the original remote to fix the command on my harmony. Now all working again.
    Thank you!! Yes I used the software and setup the device key from the T!PLus remote to program the exit on the Harmony. Not sure why the firmware upgrade would affect this but your solution works.
    Jul 2015
    Yes I do
    Which harmony remote are you guys using?
    Sep 2016
    hi
    T1+ remote response is very weak also i hate the place for group button
  1. New System Firmware Version 2.7.78
    By Capt.Kangaroo in forum Dreamlink T1 Plus
    Last Post: 11-05-2017, 05:41 PM
  2. New System Firmware Version 2.7.78
    Last Post: 11-03-2017, 11:03 PM
  3. New System Firmware Version 2.7.76
    Last Post: 10-09-2017, 04:04 PM
  4. New System Firmware Version 2.7.76 ?
    By Imp08ala in forum Dreamlink T1
    Last Post: 10-03-2017, 01:15 PM
  5. System Firmware V.2.7.70 Dol 1.06.00
    Last Post: 08-06-2017, 08:23 PM
