Results 1 to 4 of 4
Thread: T1 Plus Remote
    Apr 2017
    N.Ireland
    T1 Plus Remote
    Hey everyone I'm Paul, a newbie on the forum.
    I'm currently in the process of moving home and want make a switch from Sky to IPTV. After some research I have decided to go for a T1+ because of its nice epg and PVR abilities coming in the future. I want to completely hide the T1+Box behind my TV as it's mounted on a wall. I want to be able to control the T1+ with it hidden out of view. My question is regarding the remote. Firstly what type of remote is it? IR / Bluetooth. Will I be able to control the box if its hidden behind the TV? I have seen IR extenders on Amazon would they work in this situation?
    HTML Code:
    https://www.amazon.co.uk/ELEGIANT-Infrared-Receiver-Extender-Repeater/dp/B017XOU6RM/ref=sr_1_2?ie=UTF8&qid=1493377247&sr=8-2&keywords=ir+extender
    Thanks for the help in advance.
    It is a IR remote, and you'll need to have an IR blaster if you connect that way. There is no port for a remote IR. The T1 Plus is supposed to be Bluetooth capable. If you want a wireless method, I use a wireless mouse remote with keyboard that uses a small USB dongle, and there are wireless keyboards out there that are useful for android boxes of many sizes. They are very inexpensive. My only negative (and that's only because I haven't figured it out) is that I can't toggle power for the T1 Plus using my air mouse. There might be a learning function that I just don't know about.
    Copernicus Crater
    The T1+ is bluetooth capable but you will have to supply your own bluetooth module
    Apr 2017
    N.Ireland
    Will the IR extender i linked work as an IR blaster ? thanks for the reply.
  1. Replies: 2
    Last Post: 07-27-2019, 11:45 PM
  2. Magic Remote and Mag 250 remote Android app for 254 IPTV Box
    By zhong in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 07-15-2018, 04:49 AM
  3. T1 remote code for universal remote
    By dialupham in forum Dreamlink T1
    Last Post: 01-13-2018, 07:40 AM
  4. Replies: 11
    Last Post: 10-26-2015, 01:53 AM
  5. KR-100 Remote
    By mrgreg in forum MyGica Android TV Box
    Last Post: 08-26-2015, 07:07 AM
