Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Ftmc
    Ftmc
    Has anyone tried installing any of the kodi forks on their tv online+?
    Mercenary floder2's Avatar
    yea
    Yes..Avov has put FTMC in the Market for the Tv-Online Plus .......Works like it should............................
    yup i know they did and few more and few new updates now nova 2
    yes i do.
    do i have to uninstll kodi before i install ftmc?
    i downloaded ftmc but it would not let me download indigo.
    Quote Originally Posted by Desiguy1981 View Post
    You don't have to, it's just a matter of your storage management. As far as indigo goes, are you trying to install via a zip or via the tvaddons repo?
    yes i do.
    hey thankx for the reply. i wasnt looking at the right place. its working perfectly good.
    I loaded FTMC, is there a good all in one repository/wizard I can use? I liked spinz tv for kodi. sorry if my terminology is incorrect.
    yea
    If you go into Programs in FTMC and install " Backup " You can install from this link the most resent repositories all at the same time..........Download the file ..then unzip it... think its Rar ...... copy the folder after unzipping to a flash drive......connect flash drive to the Avov box....go the backup in FTMC .......choose settings..... browse by path..you should see your flash drive .....open and then press ok on the right and ok again at the bottom of the page....go back to Backup and choose Restore........click the folder you downloaded that's on the flash drive.........should take 5 to 8 minutes to complete ....( if you get a message saying not the same version...disregard just continue)
    Once its all done......exit to the main kodi page..and use the exit button on the bottom left of the page........sometimes it takes 30 seconds to actually exit to the main Avov menu.............
    Floder2 who are you responding to? I want to install spinztv on ftmc?
    yea
    Quote Originally Posted by keegster17 View Post
    SpinzTV is a build not a repository ...............What I posted and linked to is a backup of FTMC with all the newest repositories and addons.............SpinzTV will give you a lot of stuff you will never use
    If you just want the build Spinztv wizard ............you can find that via google ..............what I posted is more streamlined and not loaded with addons that are are never used ......Wizards I have tried just seem to slow up the operations of kodi ......All my addons are from the repository source ..............
