just over at myfriends house trying to help set up his new t6 he disconnected his switch andscanned 81,92,110,119 and 129 separately although he get's lot's of nonamebeside his channel's.when he tries setting up his 8n1
switch, he entersdisqc,then single diseqc 1.1 enters his ports to match his switch setup butwhen he exit's out it go's back to off for all the sat's he has set up , yethis dreambox h/d work's fine with this switch he can get each separate satworking ok with out the switch and has his server info set up ok
not sure if any one else has had this issue or if there is something to try
