T1 came today. Lit it right up. I connected it to my wifi. It wanted a firmware update, so I let it go do that.
The update seemed to work just fine but then it would no longer let me turn on my wifi. Bummer.
I hooked it up hardwired and that worked just fine as DHCP.
Then I got onto the marketplace an downloaded DOL.
That worked just fine.
I got my MAC off of the DOL screen and set that into my provider's website.
Then I set up my server on the T1... Bazinga! Worked just fine. Well, not quite. I had to putz with the buffer. Then it worked great.
1. What is wrong with the wifi? It set up perfectly fine the first time and ran like a raped ape.
After the update, it would not turn on and stay on.
2. Kodi 16.1 - Should I even bother downloading it?
3. How to Record?
Thanks.
