Now I don't wanna sound like a tool, but I found these 3 threads in the first two pages, and in each case its explained that recording doesn't work. In two cases, specifically mentioned "Stalker" recording not working:
http://iptvtalk.net/showthread.php?28353-Recording-WORKS-Refresh-rate-switching-WORKS
http://iptvtalk.net/showthread.php?26366-connect-hard-drive-and-record-on-256
http://iptvtalk.net/showthread.php?26832-Recording-issues-with-mag256
Please also keep in mind that recording needs to be enabled on the server side of the Stalker portal you are connecting to. 95% of them simply don't permit recording (even if your device can). Most keep it disabled because of the astoundingly huge bandwidth requirements and server upgrades that would be needed to provide that.
I look forward to hearing back from you regarding Infomirs reply. It is something I never asked them when I was discussing the bugs that needed to be fixed. They are a good company, and very helpful.
Cheers
