Hi guys thanks for all the help. My problem is channele are loading but no info on the english channels the other channels have info.
Last edited by dara; 09-06-2015 at 03:45 PM. Reason: Don't quote unless necessary.
English epg pull is currently showing no program data, so the issue isn't on our side... its at the source.
Anyone know a compatible url for showing channel logos?
Hi guys, great guide!
Followed it and was able to set it up, it finds 877 channels loaded. However, it gets stuck on loading bar with "CBS New York" displayed, then nothing happens and the bar goes away. When i go into TV in Kodi, i see all the channels but no EPG.
If i restart Kodi, all i see is "Loading channels from clients" but nothing happens either.
Any help?
Thanks!
I tried http://nfpse.********** and http://nfpsf.**********
I did manage to get them loaded actually and it did work, but still not getting the actual EPG (guide), i only get the channels with the program but i cannot get an actual tv guide
Will try that tonight.
I haven't used PVR Stalker because i am on Kodi 14 on OpenElec, there is not a stable release for Kodi 15 on OE yet. I know it works on 15 because it tried it on my windows laptop and i do get full EPG guide with PVR.Stalker, it's just Simple Client under 14 that does not provide a full EPG.
What portal url are you using in IPTV Stalker? Did you add your MAC donation info?? It should start with:
Once you enter all your settings, go into SYSTEM....then SETTINGS ....then TV....reset the PVR and EPG database. Exit and restart Kodi.Code:00:1A:78
After restarting it may ask you to turn on IPTV Stalker. Go into settings and enable IPTV.
Just FYI, before switching to PVR Simple Client, IPTV Stalker was giving me problems with the TV guide loading too.
