I was curious if using the bit.do site if I should use ""cache xmltv at local storage" in the EPG tab for the PVR simple client?
I ripped these last week when setting up the iVue guide, so there may be a few new channels missing. Worth a shot.
https://m.sendspace.com/file/az3b98
Just ignore the studios folder, that's different. The Stalker logos folder is a direct rip from the server
Yeah, that looks like a lot of work.
Wow!!!!!!!!!!! I am totally blown away by all the awesome work being done here. I seriously just had to reschedule an important meeting because I got so caught up reading all this that I didn't realize the time and missed the meeting for today LOL. Huge kudos to everyone working their butts off here.
I just want to clarify.... I am going to be totally wiping my hard drive and reinstalling everything later today. I just wanted to make sure that the original post here has been edited and updated with new info and links so I can just follow those without having to go through the pages here and do the added steps that have been updated as work progressed... Is this correct? Once I get this all set up I look forward to jumping in and helping out as much as I can.
Also, this is off topic... Once I get this all set up on my system I want to be able to copy what I have over to my sister and mother's systems. Is there a backup/copy addon or something I can use for that? If so and someone can provide a link it would be greatly appreciated.
@Shipwreck, the instructions are good, and I adjust them as necessary. As far as copying what you do, it depends on what your system is, as there is a user-accessable folder where your add-ons and userdata are, and you can just copy that over to a similar system that has kodi on it. Read this:
.Code:http://kodi.wiki/view/Backup
Basically on a PC it's at "C:\Users\<profile>\AppData\Roaming\Kodi" . Just have to copy that after you install Kodi.
OP here is accurate.. also get the latest version of iptv stalker from its thread's OP..
Google kodi backup, there are solutions on their wiki
Is there a way to set a program to record? I tried to hit record and it said PVR backend does not support timers.
