Results 1 to 3 of 3
Thread: help ?
    Mar 2016
    help ?
    I am running a nano for fta and I have mxq pro 4k can I use the mxq pro with a mac number I just update my the fta for 3 months is it doable and how to get a mac address thank you thank you
    Jun 2015
    Off The Grid
    it's not wise to post your email , this is a public forum ......boss
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    If your Donation is for IKS and IPTV service, then yes you can.
    A MAC# consists of a "00:1A:79" prefix for MAG, AVOV STB,s and STB Emulator Apps, or a "00:1A:78" prefix for KODI.
    *KODI Format Example( 00:1A:78:xx:xx:xx ) Replace the x’s, with your last digits from your STB’s MAC# or make up a random number in HEX from 00 to FF (Example: 2A:B9:43)
