To get a playlist go to your service providers portal (where you set up your MAC and do resets) and delete MAC address. When the MAC is erased, the portal will then enable the drop down lists.
Processor speed ???
On a win7PC with 6Gb ram, channels load in 1/2 second. Guide is about 2 - 4 seconds.
If you disable all addons you do not use, and delete any android apps that are running upon startup, that you dont use (use the app manager 2 C what is running), you will gain processor time and memory resources. Other than that, just trade up. $100 these days gets you a STB w/ Quad processor/graphics processor/3-4Gb ram/32Gb storage and upgraded Android O/S version. If this is your main viewing method, is it not worth it?
