Results 1 to 10 of 12
    Mar 2017
    only if it is mutual
    Clean channels from unused and speed up KodiTV startup
    Hi,
    I have Minix U1, with Kodi and stalker pvr addon.
    When I start Kodi, it starts to load channels from the provider which takes around 15 seconds. Then it starts to retrive EPG information which takes minutes.
    Also I have a large channels list with many unused ones (foreign etc.)
    I'm looking for:
    1. Method to reduce the channels list. Eventually trim it down to the ones I like only.
    2. Speed up the startup. For example update channel list and EPG only to the ones I need
    3. Easiliy access and navigate through the reduced channels list.
    Any Idea how to achieve that? I know I'm asking a lot here. Just started yesterday with IPTV.
    Appreciate in advance
    PWA aCiDjEsUs's Avatar
    Jun 2015
    On a mote of dust suspended in a sunbeam...
    Look at post number 180, should be the last one on the bottom.
    Mar 2017
    Thanks. Acctually looked in this post which is pretty long and seems like a bit of aolutions might be spread across its 180 posts.
    Read #180 though, but didn't get what I have to do.
    Do I have to use Kodi Tv manager windows app? It seems that it wasn't updated since more than a year.
    Apr 2016
    Clarke Geo Belt
    Here is what I do, I'm not going to write a huge "how to" most of my posts are all over this forum. I use Windows 10 most of the time.
    1) Download an M3U playlist from the Service Provider
    2) Download and open VLC and place the playlist in here, edit till your hearts content. I have mine down to 293 channels. Use VLC to confirm the channels work.
    3) Save your playlists, either one big one or several. I save mine to NEWS, MOVIES, SPORTS, ADULT etc.
    4) Download and install playlist loader. Select the option for no guide, so you won't have to look at the epg loading forever.
    5) Once Playlist Loader is up and running, try to point it to your newly created lists. One caveat, sometimes playlist loader can't find your local lists. Frustrating as hell.
    To overcome Playlist Loaders local list problem, I created a web server on a windows 10 machine.
    6) I installed configured apache server program to serve up my M3U lists on my internal LAN network. It's sounds worse than it is, apache is pretty simple. Change the .m3u lists to .txt. Point Playlist Loader to your newly created localhost:80 web site and or files.
    7) Download an external EPG program from Kodi. TV FULL SCREEN is very good, lots of setup options. Read lots!
    Now I can point any type of box, Windows, Android, Sony Android Television to my apache page and get my lists. Unfortunately there is no simple silver bullet solution to all of this.
    cwh
    Jun 2015
    Quote Originally Posted by HIPPOLYTE View Post
    It might be an older program, but it works and that's all it matters.
    You asked a question and I gave you an answer, but it's up to you if you'll use it or not.
    Mar 2017
    Quote Originally Posted by cwh060 View Post
    cwh
    @cwh060 Thanks a lot . I have gotten tripped by 1) already and stopped. How do I download M3U from service provider? I have a MAC number and url. When I type URL in the navigator I got "Firmare of your STB is outdated..." in a black box, it gives nowhere the option to download.
    @aCiDjEsUs Thanks, yes I have a kind of understood that the answer is somewhere in the post but it is like asking first year medecine student to perform a neurosurgery . I'm confident though I'll get to understand how to do it one day.
    Jun 2015
    This might help you further
    http://forum.kodi.tv/showthread.php?tid=245830
    It explains how to use that little program.
    Mar 2017
    Thanks, does it work with Kodi android? The post talks about OpenElec.
    If I have Kodi android I guess I have to manually copy it on USB drive, bring to Windows, modify, then bring it back?
    Also, say this step is successful, how I can disable automatic updates, and make sure KODI uses this TV29.db only and don't overwrites it?
    I know I'm asking a lot, thanks for the patience and prompt answers.
    Jun 2015
    Should work on all platforms (works on Amazon Fire TV and RPi3 and 2)
    Yes you need to manually copy to USB use with the program and then copy back to the device.
    Just don't clear your data under Live TV and you should be fine, if you clear your data under Live TV - General or Live TV - Guide then you'll have to do the procedure all over again.
    Mar 2017
    Quote Originally Posted by aCiDjEsUs View Post
    Thanks again, so after 4 hours tinkering with samba server and trying to wrap my head around I managed to modify and upload the new TV db file.
    The groups show well, no problem. However in Kodi, the EPG and channels load like before. I see my groups, but when I go in all channels group I still see all the channels that I have deleted. Same for EPG, it starts to pull the deleted channels.
    These options I put:
    In TV General:
    - Synchronise channel groups with backends (unchecked)
    - Use channel order from backends (unchecked)
    - Use channel numbers from backends (unchecked)
    In TV Guide:
    - Dont cache in local database (checked)
    (also I have cleared the data before uploading custom tv db)
    In Stalker add-on:
    - Cache guide data (unchecked)
    - Preference (Prefer XMLTV) I put a link there for the XML thinking it will update faster.
    I'm now 1/2 after and EPG guide is still updating.
  1. A clean little chuckle
    By Farmer1 in forum Jokes/Humor Forum in honor of bwcbob
    Last Post: 10-27-2022, 02:05 PM
  2. clean your PC
    By crazed 9.6 in forum Anti-Virus & Malware Protection
    Last Post: 01-28-2022, 05:05 PM
  3. Nice Clean One
    Last Post: 11-23-2019, 05:37 PM
  4. problems with kodi on startup - refreshing channels
    By webbo in forum IPTV Private Server (IPTV66)
    Last Post: 10-16-2015, 08:05 AM
  5. Unused Donations ?
    By alaron in forum IPTV Private Server (Rocket)
    Last Post: 08-12-2015, 01:55 PM
