Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 49
  1. #31
    Nov 2016
    Thank you VERY MUCH, from the VERY BOTTOM of my heart. You are very special. Any suggestions regarding The Disney Channel East HD problems? Once again, "my kids". Literally every 2 seconds it stops. Crazed, I completely understand and am well aware of other IPTV Live TV, BUT, my issue is that my kids ONLY watch The Disney Channel East and that is it, literally. You are the ONLY service that has this feed and now that I have it at least back up and running, I can't figure out why only this one channel has this problem. Is anyone able to check it on their setup and see if they are getting the same problem? At least then I know it is the server and it will be fixed, if not, I will have to continue to screw around with my "working" system and I REALLY DO NOT WANT TO MESS ANYTHING ELSE UP, LOL!!! :-)
  2. #32
    next we will get into script 101 and if you go there, then there is no turning back... you must know this going in
    Your children will be asking where you are at, after about 3 days.. They will be asking where breakfast is... You will be at the PC writing script
    There has been discussion on what you are asking about with that 2 second stop thing.
    I was reading it awhile ago here on site. somewhere
    Mar 2017
    yes I do
    I got the live Tv channels to work, but no EPG.
    Hello Kjermone,
    The Stalker Plus and any kind of Stalker is not going to work anymore. You got to install the Xtreme IPTV. Here is the complete instructions to make it simple to setup on route IKS66.
    At Least the channels work but no EPG. I am just like you, having the same problems with the new URL. I tried everything but now I got it to work again.
    My system is on my computer using windows 10 running Kodi on the Jarvis 16.1 with the ilks iptv 66 server. Below are the steps
    to get your TV working again. This may help all servers installments using the "Xtreme IPTV and the Simple Client PVR.
    Step 1.
    In your running Kodi TV program or whatever you are using, go to Systems >settings> TV or Live TV>General>
    Turn live TV "Enabled" to OFF and select "Clear Data". Next select Guide and select "Clear Data". Answer Yes to clear.
    Step 2.
    Back out of Settings completely and select "File Manager" under the "SYSTEM" Tab.
    Scroll down to "Add source" in the File Manager screen. Click "Add source" twice to activate.
    Type in the link http://srp.nu/ to replace the <None>. select done. Now enter a name for the media source as per the
    video instructions type ".rep.iptvtalk.jarvis" and select done. Now back out completely to home screen.
    Step 3.
    No"Settings" under the "SYSTEM" tap. Select Add-ons>Install from zip file. Look for your file named ".rep.iptvtalk.jarvis">
    jarvis(or whatever system verse of Kodi)>categories>video> and select the only file there
    "superrepo.kodi.jarvis.video-0.7.04.zip" wait for it process.
    Step 4.
    Select "Install from repository" now scroll down to find your file listed as "SuperRepo Category Video [Jarvis][v7] and select it.
    Scroll down to "Video add-ons" and select it. Now scroll all the way down to "Xtream-Codes IPTV" and select it.
    Step 5.
    Click the "Install" and wait for the downloading to finish and become "Enabled". Now you must right click on it for a new dialog box to appear.
    Now select "Configure" in the small dialog box.
    Step 6.
    select the Website line to enter new information. This is where your new server link will be place here. Now back the old link listed and type
    your server address: http://s1.iptv66.tv and select done.
    next enter your Username which should be your donation number.
    Next select your Password and PLEASE take your time to enter it because it is hidden with *****
    and select done. Leave the Port settings at "80" now select the OK button.
    Step 7.
    Scroll back up to the top and back out of listing until you arrive back at the "Video add-ons" screen.
    Back out again to the Add-ons screen and select "My add-0ns" which is the first listing.
    "PVR IPTV Simple Client" and select. Go to "Configure" and select. Under the heading "General" select the "Location" arrow for "Remote Path"
    Next select the "M3U Play List URL" and remove the current link information. Now type the link to your new server as follows
    http://s1.iptv66.tv/c/ and select done.
    Step 8.
    Go to "EPG Settings" and select the "Location" arrow for "Remote Path". Now select the XMLTV URL and type in the link
    http://yahyabell.com and select done. You should adjust your EPG Time Shift to fit your hours. Remember UTC is 0 and east coast is UTC-4.
    Select OK button.
    Now close the Simple Client and back out until you arrive at the "SYSTEM" screen labelled "Change Your Settings"
    Step 9.
    Select TV or LIVE TV and in "General" select "Clear data"
    Go to "Guide" and select "Clear data" and Yes to clear. scroll up to "General" and select "Enabled" to "on"
    Restart your Kodi again. Step 10 is on you.....Enjoy your LIVE TV channels!
  4. #34
    Aug 2016
    Yes I do
    awesome post Citadel.... just what I was looking for....
    ok, I followed all of your instructions and got the channels to load in the pvr but I get no guide as you mentioned but all the channels say "unknown"... about 250 or so channels...
    None of the channels play either... what did i miss ? Did I do something wrong ?
    Also I'm running Kodi 17.1 krypton and can't figure out how to turn off or toggle live tv in system and settings and live tv....
    there is no enable or toggle that I can find...
    thanks..
  5. #35
    Aug 2016
    Yes I do
    I went to set up the "iptv stalker rip" ...the built in stalker for krypton in the video addon section and it keeps saying I have an invalid serial number.... I tried disabling that feature and end up with a "404" error...
    It never complains about the "device I'd"....
    Is the serial number supposed to be a certain range or in a certain order ?
  6. #36
    Apr 2016
    Clarke Geo Belt
    @citidel, why configure both xtream-codes IPTV and Simple IPTV?
    I understand Simple-IPTV will give one a user guide, if yahyabell is working.
    I have now successfully configured:
    xtream-codes IPTV - only about 10 channels work.
    Playlist Loader - same as above only a small selection of channels work. using 4 different M3U lists.
    PVR IPTV Simple client - using M3U, same, most channels do not work. (3770 Channels load)
    Stalker Client - yesterday, I had all channels working. I need to re-assign a MAC and try again today.
    Update-Re-Assigned a MAC and tried Stalker all load, it worked, but the channels are the same as the M3U lists. Only a hand full actually work.
    So, some success for sure.
  7. #37
    ROAMING
    Oct 2015
    ok
    Quote Originally Posted by cwh060 View Post
    I cant figure this out too….when i read his post i thought Xtream-Codes IPTV was to stream the channels and IPTV Simple Client was to access the EPG.
    But that doesn't seem right.
    Would love to know ho to get a EPG with Xtream Codes IPTV.
    something here
  8. #38
    Apr 2016
    Clarke Geo Belt
    You can use this EPG http://forum.kodi.tv/showthread.php?tid=282157 set up is a bit tricky and the thread requires some reading, but it's a very nice solution and will work with xtream-code IPTV. For me the easiest is make the channels you want to view as favorites, then configure the EPG.
  9. #39
    Aug 2016
    Yes I do
    After waiting for a iptv reset, I find that the Stalker Client still gives me - authorization failed - and no channels...
    PVR iptv simple client gives me about 200 channels all saying - unknown - and none of them play...
    xtream-codes IPTV works but fewer channels than yesterday work now.....
    I was hoping to see the PVR IPTV simple client at least working with no EPG but even that hope didn't pan out...
    xtream-codes IPTV would be nice if all the same channels worked all the time making my subscription worth-while like things were before the change....
    any ideas ?
    thanks...
  10. #40
    Junoir Member mfdoff's Avatar
    Mar 2017
    Quote Originally Posted by Sdruid11 View Post
    any ideas ?
    thanks...
    I've been shopping for a replacement as it has taken too long to upgrade and have noticed with some free trials that a few of them have the same channels out at the same time which tells me that iptv66 is buying restreams that are badly serviced and go down a lot so I don't believe that is xstream-codes' fault.
  1. Replies: 1
    Last Post: 08-20-2017, 12:17 PM
  2. Replies: 23
    Last Post: 06-14-2017, 10:41 PM
  3. IPTV Stalker "Papiao" 10.0.0 - "No PVR add-on enabled"
    By sxmdim in forum IPTV Stalker (Video add-on)
    Last Post: 04-02-2016, 06:18 PM
  4. Errors when rebooting - "Authentication" and "Unable to load channels"
    By adrenochrome in forum IPTV Private Server (IPTV66)
    Last Post: 02-20-2016, 09:31 PM
