Same here,on relative's mag 254 had blocked message,then worked for a few hours,then again blocked. It's nothing we can do,they have to fix it,and yep,the donation days keep ticking away.
just tried it again on day 6 and still no go!!!!!!!!!!!
wonder what the chances on getting money back? not likely!!!
as would go with different provider a provider who cares about there costumers
If yal update your mag the problem should go away.. do a reset mac address and a update on the box..
my mags are working .. try turning your donation off and back on then updating..
u can also try putting in another donation to see if its the donation at fault
what was the exact the steps did u go through to update your mag?
last but not least .. delete your mac input another mac.. then put yours back in again
