Can anyone help me to install the best service that will work for iptv66 new server on kodi 16 on a pc
Any help will be great
Tom
Tom
Lets Go !
Sorry but does not work for me on kodi 16
For Website, make sure you leave off the "/c/",
So for rocket use http://p1.iptvrocket.tv
for IPTV66 use http://s1.iptv66.tv
for NFPS, TBD.
For xtreams-codes, it looks like you don't need to do anything with the MAC address. Just make sure you have the right route or rocket number. The Video on Demand appears not to work.
it will but you need to install the repo,
manager/add source/
http://srp.nu
then go back to
install from zip/ whatever you named your file (mine is superrepo)/ jarvis/repositories /superepo/(superrepo.kodi.jarvis.repositories-0.7.04.zip)
once installed go to
install from repository/SuperRepo all [jarvis] [v7]./video addons/Xtream-Codes iptv / install
once installed..go to the add on settings/ enter your info . Done!!
edit: important to note - right now (tried quite a few channels) getting kicked off the server every few minutes could be at server end OR who knows..maybe an ip conflict ... will reboot router and see if that helped
Thanks Phoneix that works perfect and fast
I have IPTV66, and use the built in stalker on 16.1. Changed to new URL, all works. Now, my question is do all users on all services need to use the Xcodes format now, or just those with Rocket? Thanks
Xcodes is a video addon and easy to setup
I use iks66 but I think rocket is the same but different http address
so far appears to be rocket p1.iptvrocket.tv, and. iptv66 url is s1.iptv66.tv .
xstream codes (in some way replacing IPTV Stalker Plus) is just an option for those kodi users who like to use an addon instead of pvr
Thanks for the clarification Mr. Phoneix Great info. I just love the built in stalker with Couch Potato's guide. Awesomely quick now!!
