Results 11 to 20 of 30
    Quote Originally Posted by v.i-guy View Post
    I am on 2.iptvprivateserver but nfps works on 256 I read
    yes it does, any 256 model does.
    i asked about wifi because as you prolly know that is an ac setting with the w2 model.
    Junoir Member patrocle's Avatar
    Dec 2015
    Planet Earth
    luv the avatar patrocle
    Yap, Love all the movies with those 2 guys....
    Regarding the mag, i have the 256 w1, witch has wifi too,but i am on the hard wire.
    But, my bad... i have 2 ip services,that i pay and my main one quite working , getting the loading bar while in channels, and while i switched to the service provided here it did expired, so i have to renew .
    Can't do any tests now,because not active.
    I am thinking something could be from the last firmware that was at end of feb 2017, as it di stop working from that day.
    Dec 2015
    is there any way I can uninstall the lastest update I will give that try
    Dec 2015
    Planet Earth
    That what i was thinking too, but how to get the last firmware..hmmm
    sorry guys but so far the infomir access is only for that one firmware for the 256
    Dec 2015
    I am thinking there is a bug in the new firmware
    infomir does have another firmware for the 256 and they been beta testing it.. I have seen good results but still infomir has not released it publically yet ...
    maybe some bugs v,.i-guy
    Dec 2015
    Planet Earth
    So because my active iptv subscription i have does not work, not loading at the channels, i have talk to someone and they opened a trial for my mag256 , few hours trial so i can test,at portal 2 , so i can see if that one will work, and it did ! I had all video and audio ,HD , everything was working fine! But nothing worked with my first active subscription at portal 1. Problem maybe , portal 1 comes from over seas servers, and portal 2 is from within Us servers, so we may have a internet problem, or ISP (your local internet provider) is blocking some stuff, like lines to other side of the globe, where u normally pulling your subscription from.
    To check if there is a problem with your internet,you can pink your portal http, to see if you have high .ms
    So @ your pc, go to cmd.exe and put: ping http://yourportal.com -t and observer what numbers you pulling , if the .ms is over 90 ,then that is to high and there is a internet problem,then you have to call
    your internet provider to diagnostic the line. Mine the .ms went high is 180.ms so maybe thats why from some portals may not work. Also my internet is all most half way down,from what i suppose to receive for download,so there is a problem there too. (compare to this,the ping: in cmd.exe enter: ping www.google.com -t the results)
    You can also do cmd.exe then enter this: tracert http://yourportalinfi.com
    Anyway, it could be from firmware also.
    More testing doing , hope to get to the bottom of this, wh some portals not working.
    Dec 2015
    thanks for the update Patrocle . I am going to try a different server all together and see if it works. also I was on 1.iptvprivateserver and switched to 2 but I had same problem.
    Dec 2015
    ok I have tried a totally different server I can get channels now but can't navigate through menu just locks up so I am sure this is a firmware bug I think as long as you have not taken the lastest update I think it would work fine. this was a brand new mag so I needed the update.
  1. All Channels are off line
    By jabad529 in forum IPTV Private Server (IPTV66)
    Last Post: 03-04-2020, 03:14 AM
  2. most channels down only a few can load!!!
    By Jackhammer in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 11-16-2016, 08:14 PM
  3. Replies: 0
    Last Post: 02-28-2016, 08:02 PM
  4. fuse took a update now locks up!
    By cl2224 in forum aVOV Fuse
    Last Post: 12-03-2015, 09:05 PM
  5. Disabling parental locks?
    By lstep in forum aVOV TVOnline
    Last Post: 06-14-2015, 11:29 PM
