Results 1 to 10 of 12
    Feb 2016
    i do
    stalker error doctype html public - sent here for help from PapiaoTV Staff
    Not seem to be finding much mention on this error and how to get it fixed. Using IPTV Stalker Plus 10.3.4 r6 on rocket11. Have reset IPTV several times, changed mac and no help. I also have NFPS sub and loaded that sub info on same machine and works great - so seems inherent only to rocket accounts
    Error - error doctype html public when attempting to open
    I have posted problem with PapiaoTV Staff and they have reset my account to no avail and sent me here for support in getting resolved
    I am patient person - so if this is a known issue and a fix in the mix then please say so and I will sit back and wait for a week or so
    PS - I have noticed that there is another very similar unresolved post here - http://iptvtalk.net/showthread.php?2...hlight=doctype
    Thank you for any help
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Check this post.
    It may be relevant since you are on Rocket.
    http://iptvtalk.net/showthread.php?2...164#post179164
    Feb 2016
    i do
    Yea already found that and did the IPTV reset. Cant change the portal though - I'm using Stalker IPTV addon and no where to change that in the addon. PVR is totally out due that mine is already linked to MediaPortal.pvr for local channels and can only run one PVR. Thanks for responding though
    ie reference:
    Read this, new upgrade
    We have moved to a new platform for the IPTV, first to move is Rocket, anyone getting error, please Reset your IPTV Donation using the Search Rocket in website.
    If after the IPTV Reset you keep having problems move to this new portal url: http://p1.iptvrocket.tv/c/
    Old domains do a redirect, however some Kodi users or other boxes might have problems.
    So try it out!!
    Feb 2016
    i do
    Sent here for support by Papaio support for help with this error and just nothing - come on mods how about some help with this problem please.
    sounds like you will need a different Stalker application.
    With that Stalker Plus version, you can not get the correct server URL entered.
    Until some issues are resolved, I would advise using PVR Stalker client.
    http://iptvtalk.net/showthread.php?2...et-up-tutorial
    - Frank Zappa
    Jan 2017
    Yes, you will get live TV if you set up the stalker client , add the new Url. make sure you disable and then enable the client and reset your donation. ( works for me On Kodi 16 -windows 7 PC version ) the add on IPTV Stalker Plus 10.4.2 has a script error, i assume because changes made at the server end, and the add-on now has bad code thus is spews all over your screen.
    I have the same error for the last week or so...kodi 17
    i reinstalled PVR Stalker Plus and re-entered all the info under settings.
    Also i reset the mac on the rocket site and nothing...
    i'm not sure what the problem is...
    Quote Originally Posted by theviZitor View Post
    Oct 2015
    Quote Originally Posted by coolsatri View Post
    i can confirm this..it worked with my pvr stalker client addon for live team section..video addon sltalker client plus doesnt work still..but hey..atleast im getting channels..
    Jul 2016
    how do i move to the new portal?
    Dec 2016
    Wouldn't you like to know
    Can you recommend an alternative?
  1. Question public
    By ivan56 in forum New to IPTVTalk
    Last Post: 07-16-2021, 09:41 PM
  2. I can not connect to http://mw1.iptv66.tv/stalker_portal/c/index.html
    By cperez90008 in forum IPTV Private Server (IPTV66)
    Last Post: 10-07-2016, 10:38 PM
  3. Replies: 9
    Last Post: 09-09-2016, 03:08 PM
  4. Replies: 17
    Last Post: 04-16-2016, 05:23 PM
Tags for this Thread
