Results 1 to 3 of 3
    Feb 2017
    Recording issues with mag256
    Hi.
    Firstly, loving iptv. Great move.
    Now, I have purchased a 1tb external hard drive and formatted it to fat32, but I cannot record, I can set up a recording on the TV guide but nothing records.
    On the main portal screen the recording manager has no PATH and no option to fill it. I am at a loss. Please help.
    By the way, I am on rapid iptv if it helps.
    Thanks in advance
    Dec 2016
    Are you on the latest firmware?? There is no recording through the stalker portal, but I think you uss an .m3u file, correct? Which means you added the channels to the inner portal IPTV area I think. Maybe you should try with a simple USB drive (possibly better compatibility), try FAT32, NTFS, EXFAT. I am not sure how to set the drive up. There were a few time shift options in the inner portal settings, I don't know if they would affect this but might be an idea to check out. If you put a random file like "test.m3u" on your hard drive, can you see/open that file on the MAG?
    Android World
    We donot talk about other providers on here please edit post.
    Lets Go !
  1. 2/11/20 update causes recording issues
    By curgs in forum BuzzTV 3000 series models
    Last Post: 02-19-2020, 06:12 PM
  2. recording issues with new T2
    By mzador in forum Dreamlink T2
    Last Post: 05-08-2018, 04:57 PM
  3. Mag256 Download issues
    By Boxy345 in forum MAG 256 & MAG 257
    Last Post: 02-07-2018, 06:59 PM
  4. multiple server boot issues with mag256
    By rental in forum MAG 256 & MAG 257
    Last Post: 01-28-2017, 09:51 PM
  5. Issues with MAG256 Reboots
    By VikasB in forum MAG 256 & MAG 257
    Last Post: 08-20-2016, 02:03 PM
