Results 1 to 7 of 7
Thread: please help me
    Probation
    Feb 2017
    please help me
    I just bought a new ott box arrived today plug in HDMI cable
    all I get on tv screen is box that says
    4 core
    mali 450
    quad core
    s805
    no matter what I do cant get anything else
    remote new batteries
    just wont move off that screen
    thank
    wow unplug the box and try again and pug in the internet
    Probation
    Feb 2017
    Did that but still no joy thank
    they may not of flash it need read how to do that and where to find the files or pm them and say whats up with this
    Sep 2017
    Bulgaria
    please help me
    hello...i accidentally clicked the romdump option and now my htc one m8 wont restart or even start...cant do anything to it...please help
    Warrior Member
    Suggest trying Android Box forum.
    Readings Master kens's Avatar
    Feb 2016
    yes i do -Y(not)
    Unplug the unit.
    Get a toothpick and insert in the AV Port until you feel a click (uSwitch at back of port)
    Hold switch in and plug power in to the box.
    Keep holding in switch until graphics appear on screen, then release.
    Unit should factory reboot.
    If not, you will need an SD Card type Firmware flashing file set, and it usually has to be explicitally for your Build #.
    Try Googling China Gadgets direct or try this link ->https://www.entertainmentbox.com/
    GL
