Results 21 to 30 of 33
Thread: not updating
  1. #21
    there are 4 new update files.
    Two for the Avov Vixo1 model.
    Two for the Avov TVOnline model.
    Each model may come with one of two builds, that's why two files for each.
    So get your correct avov receiver and get the correct update file depending which build you have.
    This is all explained in the directions. Don't randomly try files. Get the right one and try that same one a few times.
    Couple reports that I saw, said they were successful after a few tries (with correct file)
  2. #22
    http://iptvtalk.net/showthread.php?2...date-4-27-2015 thats the one for you its vixo1
    *Remember:
    – Make sure your device is connected to the internet via Ethernet or WiFi then continue with the steps below. Do not pull USB/SD Card/Jump drive until the firmware installation is completed.
    – Please do not download all files and put them on same drive it will not work. Its 1 USB per “update.zip” / device / firmwarm update. The file must also stay named “update.zip” for the box to recognize the firmware update.
  3. #23
    That is the file I used, but will try it again. Thanks.
  4. #24
    Step 1: Check which is your build number by going to: “settings > system info > build number” you must do this read and read
  5. #25
    also make sure your Browser is not downloading the file as an attachment... If it is, then change the file name to 'update' and try that.
    Or change your Browser and use FireFox and then re-download a new copy of the update file..
    Thnx papasmurf for that info
    Quote Originally Posted by papasmurf View Post
    I had the same trouble then I found my windows. Download the file to the name( attachment) I rename it to(update) an it work like a charm
  6. #26
    I did that, build number is 1.0.10
  7. #27
    I am at 1.0.11 and came up as update. I have tried this update numerous times and also did a factory reset. Now I have no apps and still can't access the channel store. Does anyone have any ideas on how to fix this problem? Thanks
  8. #28
    yea email them and make a ticket and they will help you are you on the internet with this box ? here
    http://help.avov.tv/
  9. #29
    Well now all at once the Mickey hop came up and I can now add the apps. Hope everybody's will do the same.
  10. #30
    How long does it take the firmware to update from 1.0.09? Trying to update a new vixo 1 box but stays on firmware updating message.
  1. VOD - Updating list
    By rocket77 in forum Media Players / M3U Playlist Players
    Last Post: 09-20-2018, 08:46 PM
  2. Problem updating m3u
    By alblues2 in forum IPTV Private Server (IPTV66)
    Last Post: 08-24-2017, 11:26 AM
  3. Epg not updating
    By kroakie1 in forum EPG (epg.ninja)
    Last Post: 05-19-2016, 06:58 PM
  4. Updating mag 254
    By blondi in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 11-21-2015, 01:50 AM
  5. Updating Mag254
    By cpr43 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 03-27-2015, 10:20 PM
