Yes mag 254. You've got the same!!! No solution yet, that's why I'm here.
I updated it to lasts weeks firmware but when the blue screen with yellow bar comes on it downgrades it back to the old one!!!
It's driving me nuts, just changing the theme has done this! There doesn't seem a way to undo it.
If there is no critical info displaying maybe you should take a picture of your issue and post it here im sure someone can help
Lets Go !
I've got pics, how do you put them on?
when you reply there is an icon above with insert image.
if there on your phone just email them and open up on pc
Hello All,
I have recently got a OTT TV BOX, but recently there has appeared an advertising bar at the bottom of the screen with a "pop up" opening up every 3 minutes and then a full web page, no matter what app I am using; Show Box, Mobdro, Kodi.
Does anyone have any ideas how I can eliminate this issue?
The Western Wanderer.
frustrating
some images will not load on site here.
You can use a file host web site and post piucs there and then just share the link with us.
you can use a site like mediafire.com
They want you to register there to use their services , but you can use a false name and false email (long as it has a valid email extension)
