Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 50
    Feb 2017
    Ok
    If I use the gears button below the blue button I get a menu screen but nothing seems to help. I'm not sure what I'm doing so hesitant to mess around with much. It did this because I wanted to change the theme!!!
    what theme or in what menu were you trying to change ?
    Bkman mentioned to try another TV
    You may have put the receiver into PAL mode, which some TVs are not compatable with. The Mags factory default is PAL mode.
    If you can take it to another TV and try, it may work, if this is the trouble.
    Feb 2017
    Ok
    I changed the default theme to graphite. I thought it would be clearer.
    i do not even know what menu you found that theme option
    Are you using a Mag254 iptv receiver ?
    Or is it another receiver ?
    Feb 2017
    Ok
    Different TV same problem! Argh!!!!!
    Feb 2017
    Ok
    It was in settings and I can remember which tab now. The blue theme is the default and it offers you ocean, green, cappuccino etc. I've done it before and it wasn't a problem.
    Feb 2017
    Ok
    Tried an update, no joy.
    Feb 2017
    Ok
    Help, still no TV!
    Apr 2016
    is that a mag 254 ?
    Feb 2017
    Quote Originally Posted by bobopool View Post
    is that a mag 254 ?
    I've got exactly same problem, changed the theme in the iptv client and after reboot it flicks between blue screen with yellow bar and a black loading screen!!
    any ideas??
    setting default in bios doesn't work, is there way to completely wipe it?
  1. stb emu stuck at loading
    By coreyman2 in forum IPTV Private Server (Rocket)
    Last Post: 10-17-2016, 12:29 AM
  2. stuck on loading
    By mello1d in forum IPTV Private Server (Rocket)
    Last Post: 08-03-2015, 04:06 PM
  3. Mag 254 stuck on loading
    By eyepopper in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 07-02-2015, 10:32 PM
  4. Mag 254 Stuck Loading
    By MoneyTK in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 06-09-2015, 10:47 AM
  5. mag 254 stuck on loading
    By bingolong in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 02-10-2015, 08:44 PM
