Ok, no surprise. Stalkerclient authentication failed. After first attempt at setup. Here is what I’m using and how I configuredit.
Using firetv stick newest generation
Kodi 16.1 with fusion/tvaddons
Pvr stalker client by Jamal Edey version 1.0.8
Used setup sticky PVR Stalker (Kodi Built-in) Set up tutorial
Receiveddonation number from iks66.com.
Configas follows
General
Active port 1
Connectiontime out 120
Portal 1settings
Mac address00:1A:78:XX:XX:XX as received from iks66
Server address http://mw1.iptv66.tv/stalker_portal/c/index.htmltried leaving off http:// still failed
time zone America /Eastern should effect anything??
Login 13 digitroute number from iptv66
Password 13 digit route number from iptv66
Guide
Preference PreferXMLTV
Cache guide data on
Cache time 24
Scope Remote URL
Remote URL http://yahyabell.com
Token Blank
Serial number XXXXXXXXXXXXA 12digits and 1 capletter
Device id xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx x
Some big ass long alpha number generated by some web sitederived from the combination of the serial number, route number, and macaddress I inputted. I don’t know. I read it in some thread here that said itwas required as of Feb. 1st.
Device id2 blank
Signature blank
Tried to disable, clear cache, enable exit Kodi, forcestop, and reopen several times no go.
Any help here appreciated
thanks
