I put in new mac address did not get any reply good or bad
go back to that same webpage and ensure the same MAC is still there, re-enter it if needed... and then perform an IPTV Reset , then you will see a message of success or failed
still no luck changed mac address did not say it was good or bad so will try again tomorrow thanks for the help I did go back tried to go to checker just keep asking if I am a robot
left click my name and send me a message and I can check on if it worked, or link if needed.
I will need the MAC and your number or email
you did get it change with success, but the last digit at the website shows a 7, while what you sent me shows a 1 as the last digit.
Leave it as a 7 at the website now, just change your MAc on the stalker to match.
I sent you a reply message.
Still can get my box to work .Would it be a good idea to uninstall kodi and reinstall clean version to see if it is just curupedted if so what is the best version to install
I doubt your installation is corrupted. Rather, there is most likely a configuration issue.
At this point, here is what I would do...
Disable PVR Stalker and set defaults. Shut down Kodi.
Go to the Donation Checker. Make sure all your settings look proper. Jot them down so you have them for re-configuring PVR Stalker later.
While at the Donation Checker, do an IPTV Reset.
Wait at least 15 minutes then restart Kodi, but do not enable the PVR. While disabled, configure the PVR following these directions to the letter:
http://iptvtalk.net/showthread.php?2...et-up-tutorial
Once completed with the configuration, making sure everything is accurate and complies with the directions, enable the PVR.
John is using Kodi16+
so, ensure server URL is as below...
Code:http://portal2.iptvprivateserver.tv/...l/c/index.html
Ok thanks will try soon as I can
I have shut down kodi and reset iptv will see what happens later
