Have seen quite a few issues related to the EPG in the various 17 betas? Glad you got it ironed out.
I can't load the guide. When I go to the url on my phone or computer it shws the coding for the guide. But when I go to kodi it says cannot load guide. If I go into the android browser on my box I also can't load the url.
It redirects to a gethub address, like on my other devices, but never loads passed that.
Is the server blocking me or something? I cleared cache, restarted my android box, and Internet and still the same thing
It should redirect to the Github address. That is where the guide is hosted. The guide is loading on my Kodi this morning, so I'm not sure about your issue. Did you clear guide and channel data and let them reload?
Any ideas on incoperating this epg method to papio iptv stalker?
Lets Go !
I don't, since I haven't used it in conjunction with PVR Simple client for many months. That was the only way I used it with the guide in fact. I never used Couch's mod.
Have tried a guide clear and reload in stalker on 16.1 but still have no program info.....would appreciate a p.m. with any suggestions
Have you ever had this guide working in that Kodi installation? There usually isn't a problem with K 15 and 16 and the guide. Make sure everything is set-up correctly. Check the spelling.
Thanks, I've been waiting for some guidance on getting a guide up and running. You are a lifesaver...Awesome..Thanks again..
I don't get it... I have it configured exactly as op. But it always fails to load... I'm working in a android device with kodi 16.1 could someone getting working on this?
