Results 1 to 3 of 3
    Apr 2015
    TV.online+ WIFi issue _avon_box
    Hi i have a tv online + I got this year .Never noticed that wifi was not working, I been trying everything I know went in from Kodi under program ,went in from setting from device it seems that it is off but can not get it to turn on .Does not matter what I do no wifi comes up will not recognize .Did a test and it says not turned on ,does anyone know how to turn this Avon box wifi on ,hope someone does thanks..Happy holidays to all IPTV talk!!
    tester
    Yes I do
    reboot your router and modem are factory reset TV.online+ i think the only time the wifi should not be on is when you have a internet cable plug in to the box
    Yes I believe you are correct Greg if internet line is hooked to the box there will be no wifi
    Two of the greatest qualities
    to have in live are:
    PATIENCE
    and
    WISDOM
  1. Wifi Issue after software update
    By Keyboard in forum Dreamlink T2
    Last Post: 08-04-2021, 11:15 PM
  2. Wifi connect issue
    By HumK in forum Dreamlink T2 Prime
    Last Post: 09-25-2020, 02:19 PM
  3. MAG 250 WiFi SSID Detection Issue
    By Mattd in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 03-21-2017, 03:58 AM
  4. Wifi issue
    By RonTheRipper in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 05-12-2016, 01:52 PM
  5. avov online wifi
    By sammy64 in forum aVOV TVOnline
    Last Post: 02-02-2016, 04:26 AM
