Nah, it doesn't require a certain version of windows. SD has an announcement on their website that their downstream providers for Great Britain changed some things so they had no choice but to also make some changes. Just run the mc2xml like it's the first time and put in GB and just use the partial postal code they use as an example in the interface (SW..) and get the list of providers. I used to use BSkyB and now I use Sky HD - National (National). Just pick the provider and let it run to get the new channel IDs and simply change your batch files to reflect the new numbers/IDs.
I think the changes went into effect December 17th or something like that.
The JSON Sched Dir service migrated to new grabber zz_sdjson
*Info;
DESCRIPTION
This is an XMLTV grabber for the Schedules Direct
(http://www.schedulesdirect.org) JSON API.
tv_grab_zz_sdjson - Grab TV listings from Schedules Direct SD-JSON
service.
Thanks Kens...I got it to work. Thanks for the help everyone.
I'm a little confused here. What do i have to do to get a good working guide for the U.S. and UK?
Here are two
Code:https://raw.githubusercontent.com/acidjesuz/EPG/master/guide.xml https://raw.githubusercontent.com/kens13/EPG/master/guide_kens.xml
I don't think either of those are working ilan. Can someone confirm if these are working. Not having any luck with them.
