I have deleted and installed again but i have an issue of it loading and loading forever then any channel i'm on start buffering every 5 seconds however vod works fine ppv fine just regular tv channels .
Try doing a modem reboot then a iptv resetc see if that helps
Tried all that still the same but thanks
which sever are you using ?
I have uninstalled it as per the instructions but when I go to Market the only one there is 805 how to I go back to 803 0r 802 ?
Yes Only 805 is available but problem is fixed for most of the servers. Some servers are still having issues like loosing Fav and video not available etc
Take a look at this
With the latest release of t1 there appears to be an issue when using a provider that requires a username and password.
Not sure if I can say the provider. But I did pass onto them my issue Cannot log into provider that has username and password is required. here is there response.
Jan 20, 16:01 AST
a lot of dreamlink t1s are after the last update hopefully they fix it soon you can try using a vpn look in the market or even look into a google public server yo ca google it
my dreamlink t1 says the same thing check internet connection and url i updated the day it came out then they pulled it and since then i also cant use mine on a donation that requires a password and username i hope they fix this issue and i also have taken my box to another place and did the required iptv reset and still get the same message
With this 1.08.05 update I still get box message with can't play video and then freezes if you pick a channel that is down hopefully a fix is released soon also sometimes wont load at beginning have to exit out and retry to load channels didn't have this problem with previous version update
