Results 1 to 7 of 7
    Nov 2015
    yes i do.
    guide to setup ivue with stalker client built in for jarvis ?
    i cant find i guide for setting up ivue2 with javic built in stalker client. sense epg stalker is down im trying to set it up. cant find iptv stalker or the newest version of pvr stalker most links are down not available. can someone make an updated guide for this? with links
    left field
    Quote Originally Posted by godassassin View Post
    In order to have the most current version of the pvr stalker, upgrade to the latest KODI version. It comes preinstalled. If you want to use a guide addon (Ivue or other) you need to save every stalker channel to favorites and then select the appropriate choice from within the Ivue addon. Depending on your hardware, you either long press, hit menu or 'C' to bring up the option to select stream. Then you move the cursor to highlight KODI favourite and scroll to the channel you want to link and save.
    There are youtube videos, kens also has a sticky about this as well. Ivue has a Facebook group page to answer these questions. You are not looking hard enough.
    Jul 2016
    Hi. Where do I go in kodi to upgrade? Because I usually do it through Google play.
    Thank you!! 😊😊
    left field
    Quote Originally Posted by Lightbolt View Post
    Thank you!! ����
    You don't do it in KODI. KODI does not auto update, only addons do. Either download the latest version from Google Play or go to kodi.tv and get the android version there. Or get SPMC.
    Bulletproof
    Thanks expatter for your info. So it will work with SPMC also ?? I have KODI 16.1 working great. .. andkaal
    left field
    Quote Originally Posted by andkaal View Post
    Yes, it works with SPMC. Anything Kodi (android) can do, SPMC can do...probably better!
    Banned
    Aug 2017
    usa
    does anyone have any pictures of the ipod video with an ivue panel but a black OEM click wheel?
  1. pvr stalker client (kodi built in)
    By hreynoso1 in forum PVR Clients
    Last Post: 04-07-2016, 02:22 PM
  2. Stalker Client on Jarvis 16
    By Standen1986 in forum PVR Clients
    Last Post: 02-01-2016, 03:11 AM
  3. Mind is boggled: Stalker Client & iVue Guide help?
    By rossws in forum IPTV Private Server (NFPS)
    Last Post: 11-09-2015, 10:28 AM
  4. Video Tutorial Stalker / ivue guide / pvr simple client
    By xbmconnect in forum Kodi Tutorials Stickies
    Last Post: 07-18-2015, 11:00 PM
  5. INTEGRATE IPTV STALKER WITH PVR SIMPLE CLIENT & iVUE EPG GUIDE XBMC
    By farwoof in forum Kodi Tutorials Stickies
    Last Post: 06-12-2015, 01:21 PM
