Results 1 to 6 of 6
    Aug 2016
    Auto updated to 10.3.5 then did not work
    Got updated to 10.3.5 then icon changed to "something else" and stopped working.
    Had to change back to 10.3.4
    You will need to determine which repo did that to you, and disable it. For the servers supported here, the only way you will be able to get ISP, or ISPL is via the zip files posted by the author.
    Dec 2015
    Yes I do
    Quote Originally Posted by johnny22 View Post
    Hi Johnny22, You did not tell us which device you're using.
    Aug 2016
    It did it again, I uninstalled it and reinstalled from zipfile 10.2.4 (did not have 10.3.4) turned Auto-update off, still it shows the competitor icon though it is 10.2.4. How do you change it back to IPTV icon?
    Aug 2016
    Quote Originally Posted by Dmarlehole View Post
    android M18
    You'll have to refresh the thumbnails. Do a google search on how to manually do it, but there are add-on that can do that for you, as well.
    Uninstalling first also might help.
  1. Replies: 22
    Last Post: 04-03-2019, 03:04 PM
  2. Had auto update on Kodi&it updated to 18-sub doesn't work now!
    By puckett59 in forum IPTV Private Server (NFPS)
    Last Post: 01-30-2019, 08:22 PM
  3. Auto shut down
    By Jimc197 in forum Dreamlink T1
    Last Post: 05-03-2018, 10:55 AM
  4. How to Auto Update Mag 250
    By Bkman2020 in forum Mag STBs - Sticky Threads
    Last Post: 01-22-2017, 10:24 AM
  5. Replies: 5
    Last Post: 09-02-2015, 11:14 PM
