I went there but will try it again after work
blue icon? correct?
blue icon? correct?
I have it on list view. I do not see the icon. Am in midst of something thou and can not check right now.
Did you know that when in them views, scroll to the left all the way till a side window opens. Click on the top option to change the view.
Exit by scrolling right.
Then hit the menu button and Set as View and it will save as that view mode.
Is this with PVR Stalker client? If so, it sounds very much like you have a mistake in the portal address you entered. Check for typos. The slightest mistake will kick up an error.
If you're using Kodi 15 or earlier, use
If you're using Kodi 16+, useCode:http://66.iptv66.tv
Code:http://mw1.iptv66.tv/stalker_portal/c/index.html
16 that's what I'm using will try again
Yes, report exactly what the errors were. What version of Kodi are you using? What is the exact error message you get when you use the URL appropriate URL for your donation? What are the first 6 characters of your MAC address? You created all the credentials specified in the directions when you were configuring PVR Stalker cleint (i.e., Serial Number and Device ID)? Do you do an IPTV Reset with Kodi shut down before you enabled the correctly configured PVR Stalked cleint for the first time?
The PVR Stalker client works if it is configured correctly. There is a problem somewhere, but most of your messages give me little to go on.
error: HTTP 404 Not found
Kodi version 16.1 (Jarvis)
MAC: 00:1A:78:xx:xx:xx
have also seen error MAC 1 invalid (but appears to be gone now)
no serial no or Device I.D. (not sure if I need this and where do I find it )
Yes do IPTV reset with kodi shutdown and add in disabled
Somebody please help
