Results 11 to 20 of 34
    If you haven't enabled it, I'm fairly certain it is disabled. You will find it following this or a very similar route...
    System > Settings > Add-ons > My add-ons > PVR Clients > Stalker client
    Nov 2016
    yes I do
    That sounds more like an error thrown by IPTV Stalker Plus video add-on than by PVR Stalker client? If it is IPTV Stalker video add-on, you'll need to disable it, set defaults in it and then reconfigure it. Setting default is the key. You'll need to wait until you have access to the Donation Checker because you'll need to do an IPTV Reset after configuring IPTV Stalker Plus but before enabling it. You need to make sure PVR Stalker is disabled, too. You can't have both enabled.
    EPG = Electronic Program Guide
    There's no way around the 24 hour lockout.
    I went to https://iks66.tv/main/search
    put in my order info got window with my info MAC address ,server name
    I hit reset and it says IPTV reset was successfully updated
    now I get unknown url type 66.iptv66.tv/stalker_portal
    It sounds like you're configuring PVR Stalker client now, as IPTV Stalker Plus shouldn't be throwing that error?
    Was the MAC address you entered previously successfully accepted?
    You're most likely using a Kodi 16 version, correct? If so, the proper URL for configuration would be
    http://mw1.iptv66.tv/stalker_portal/c/index.html
    Nov 2016
    yes I do
    it didn't say success it just returned all info I should be using and had button to reset IPTV which I did and that was successfully updated
    now I get IPTV STALKER RIP HTTP error 404 not found
    Nov 2016
    yes I do
    Unhappy
    Quote Originally Posted by espringer View Post
    Is there anything else I can try I have follow everything mentioned
    even tried in exact same sequence
    first I see error Custom mac1 is invalid
    after i get message MAC was updated on the portal
    then I get
    any help would be greatly appreciated
    tester
    Yes I do
    do iptv reset then try see if that helps
    Nov 2016
    yes I do
    Quote Originally Posted by greg View Post
    Thanks will try that after work
    I that with my last post but will gladly try it again
    It now sounds like you are back to configuring IPTV Stalker Plus? I would configure PVR Stalker client. Work with it until it succeeds. This way, we are back and forth and never get anything hammered down.
    Check to make sure the MAC address is correct in the Donation Checker. If you changed the MAC address and then did an IPTV Reset at the same time, there is a chance the MAC wasn't saved.
    The IPTV Stalker Plus error is most likely due to not setting defaults at the beginning. There is remnant data causing issues.
    Nov 2016
    yes I do
    I have not been able to find the PVR Stalker client
    supposed to be built in to Kodi not finding it
    can I get it from somewhere?
    System - Addons - My addons - PVR Clients - Stalker Client
    (when in PVR Clients, scroll page down to get the the S for Stalker, in the descending order)
    Version 1.0.8 is showing there
  1. Linking MAC page down
    By apollog in forum IPTV Private Server (Rocket)
    Last Post: 04-01-2023, 10:04 PM
  2. Problems linking mac address
    By geevee in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 01-25-2017, 12:23 AM
  3. Linking mac
    By pitboss in forum IPTV Private Server (Rocket)
    Last Post: 02-24-2016, 05:02 PM
  4. Linking channels
    By Daniel8520 in forum IPTV Private Server (IPTV66)
    Last Post: 11-19-2015, 02:59 PM
  5. MAC address not linking
    By tallman in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 11-10-2015, 06:51 AM
