Results 11 to 20 of 23
    Yes! I now have Nova Launcher as the default home app.
    Since I kind of hijacked the thread from your praise of Avov, to how to sideload apks, I changed the thread name... My fear was that despite the pretty good hardware, the limits of Micky Hop were going to doom this box to only running an adapted version of Kodi. Now... if only if we can root and get aptoid or google play on this thing!
    No worries about the name change it was a good idea. Part of the reason I made the post was to help others who still didn't know how to load apk
    I'm gonna try it tommorow morning hope it works well
    Couldn't wait tried it now. man it worked out really well so much easier to load apps, tnx friend
    The Vixo 2 has no application launcher in Programs-Android apps...
    I don't think that vixo has that app. I tried to find it in my tv online plus but couldn't find it either. I think it is only in the tv online 4 as far as I know
    Oct 2016
    umm , i posted how to root and install google play here
    look only box that can do that is 4k i posted that long time ago with a how too now i never try root thing cant say if it works
    and here is what i posted
    update it worksyou are right i asked if they can make it work just now update at 82 % lets see if it works for me 87 megs big is that right? nope didnt take in android apps got it to first movie now you see me 2 says site back may take few mins wow got t working in programs android apps
    This is what i did
    downloaded 4-66 would not let me do 69 on stick
    next did this this is copy and paste
    @rudawgg Here is what I did to install some apks in my AVOV TVOnline 4 :
    1 - Download the apk of the app that you need from the internet (you can do that directly via the browser or using your PC and a USB drive or memory card, ...), there is a lot of websites to get that or you can copy it from any rooted android device.
    2 - After installing kodi, run it, go to "Programs" >> "Android apps" (here you will get all the installed apps in your box) >> "Settings" (here you will get the settings window of android), then "Security and restrictions" then turn "unknown sources" to "on", and "verify apps" and "restricted profile" to "off".
    3 - Then back to kodi >> "Programs" >> "Android apps" but this time go to "AppInstaller" (the app which we will use to install apks), then select your source (local disk, memory card, usb drive), the app will search all available apks, then you have just to pick (check it at the right, don't click) the one that you want to install and on the menu at the top right, click "install".
    That's all.
    @ecko665 You have just to do the 3rd step (check then "install", no click).
    it didnt work then took stick off went back to android apps scroll down to show box click it said need update was 87 megs big after that
    scrolled down to show box again and it loaded so it works in program android apps
    Quote Originally Posted by romstah View Post
    Thanks... I missed it. I'll sticky it.
    Dec 2016
    Nice work I can get use to this android stuff as I love android phones. I'm having a blast with my avov tv online 4
    I am just afraid to root the device because I don't want to mess it up and don't want to go through the hassle of rolling it back for updates. If you can recive new updates I might give it a try I'll wait to hear from the guys who rooted thier box if they recive the new ones
  1. Sideload Launchers for Hulu, Chrome, and Netflix
    By mavblues in forum Formuler GTV
    Last Post: 04-20-2021, 04:47 PM
  2. can you sideload an APK into the dlite?
    By jphccfc in forum Dreamlink Dlite
    Last Post: 01-05-2018, 08:49 PM
  3. SideLoad Apps on Avov Vixo2
    By rudawgr in forum aVOV VIXO 2
    Last Post: 01-03-2016, 05:19 AM
  4. Sideload?
    By tinman_hd in forum aVOV TVOnline
    Last Post: 07-31-2015, 01:27 PM
