Results 11 to 20 of 27
    Thank you for you support........
    we are all here as family to help and getting bigger
    Thank you my friend......asft I have another matter that concern me,i got me a new avov 1 box from Canada and for some reason it won connect to server on the tv on line app......I have check every detail carefully and don't see misstakes,any suggestions?
    Moderator at Work
    Try a reset press Off on remote for a few sec until box comes up, choose Reboot see how it is after reboot.
    Member Switchon's Avatar
    Jan 2015
    Can you get into the Channel Store? If so try running one of the other apps like FilmonTV?
    If you hold down the Remotes power off for a couple of seconds a popup will show up, just pick reboot.
    Sometimes unplugging the power and letting it reboot a fresh will reset it too.
    Are you using a 2.4G device i.e. mouse or keyboard, sometimes that will interfere with communication? I have a mouse and keyboard but have to re-boot if I plug it in while up and running.
    Thank you my friend,no I don't have none of those devices,i tried wit rebooting and factory reset ,my new box utdated is 1.0.11 ,I have one that is connect to server wit vercion 1.0.10,this is driving me crazy ,this new box I got it from Canada....the one im using I got it from seller on this side,if that may be the problem? I need your sugestioms friends,it have 8 hours and my ivov just wont connect to server........1.iptv privatesever.tv.....do I have to add anything else?
    Moderator at Work
    Should be no space between iptv and privateserver.tv and check spelling.
    Jan 2015
    Can you get to Channel Store and install apps, if so try to run a movie or live TV in a different app?
    If you can Check your setup and spelling in TV Online ----> http://iptvtalk.net/showthread.php?5...-Avov-receiver
    Thanks guys,there is no spaces.....1.iptvprivateserver.tv........
    Yes switchon ,I have downloading apps and running movies ok.....in any app.......wit no problem.....
  1. Lost my whole house Wi-Fi connection
    By Yellowray in forum New to IPTVTalk
    Last Post: 03-24-2018, 09:43 AM
  2. Help with server connection.
    By lennonbb in forum Introduce Yourself
    Last Post: 08-03-2016, 04:30 AM
  3. No connection to server
    By Atagilbert in forum IPTV Private Server (IPTV66)
    Last Post: 04-09-2016, 06:51 PM
  4. Mag254 lost connection...
    By r3dp0is0n in forum IPTV Private Server (Rocket)
    Last Post: 02-10-2016, 03:43 AM
  5. Stalker Client Failed to Start, Connection Lost
    By nemesis668 in forum PVR Clients
    Last Post: 11-29-2015, 07:32 PM
