unless you have a rocket donation which would be 11.iptvrocket.tv
they are not using the correct address for their donation
At step 10, I got a black screen. tried to exit like the instructions, but still the same. I waited 10 minutes and nothing happened. I unplugged the box since I have to go to work. Thanks
Well after a lot of reading and trial and error, I am watching TV. After about 10/15 times trying the reset method , it finally reset. Started the setup again accordingly to the sticky guide, and everything went smooth. I don't know what happened the first time.
portal url is now 11.iptvrocket.tv/ try this address
Hi Guys, Initial setup doing everything listed I get to the blue screen with progress bar and that's as far as it goes. I have tried unplugging and plugging back in with no success any ideas ? Thanks
Hello, I have set up everything and the only issue I havenis when the mag254 opens up, itbdoes so atba channel, I really want to change this, I have it set to main screen and have rebooted twice now to lock in that feature but it still wants to stay on the channel after I exit and return,
I hope someone can guide me to resolving this
Ty
"13. For "Portal" it is best to leave it at main menu if you have limited bandwidth, so it doesn't come on to live tv without anyone watching it."
Hi BIO
Aren't we required to load a firmware into a new box, If so where do I go to find where it is posted... Thanks for your answer... Nadman
