Mode not supported .change resolution of external device.thats what on the tv screen when I turn on mag 256.any advice is greatly appreciated ,thanks
unplug mag 256 crab the remote for mag press the button that has 3 lines on it hold that plug mag back in enter bios change resolution to auto should work
Hi,just did no go black screen ,thanks
you dont have the av cable for the mag 250
no,just hdmi
did you go in to bios change to auto resolution should be good
I cant,its showing mode not supported black sreen,I will try to hook up rca cable and let u know,thanks greg..
