Phewwwwwwww, thank you. Because I have a lot of expectation on this box and really have waited long time for it to come out and really I don't want to be disappointment.
Looking forward to put my hand on this great device.
david_avov, can I assume that all pre-ordered boxes were the first ones out the door?
Just got the tracking, coming from China? That's a surprise
DHL just delivered mine! I'll let you know when I get it running.
Up and running. Here are some quick thoughts:
The setup of the Avov 2 is identical to the Avov 1 box. Cabling is easy, but be sure to connect the HDMI cable to the "out" port. There are 2 HDMI "in" ports on the Avov 2. The power supply is different from the Avov 1, so if you've got a Avov 1 box you can't just unplug and plug into the Avov 2. The remote requires 2 AAA batteries and is improved from the Avov 1. The game controller needs 2 AA batteries.
I immediately loaded the TVOnline and iLive apps to watch IPTV. My initial reaction is that IPTV picture quality is about the same as it is on the Avov 1 box, a 720p look. Since some channels look better than others, I agree with others on this site that IPTV picture quality is as dependent on network and picture encoding factors as it is box related. I will be doing some side-by-side testing of the Avov 1 and 2 to be more certain.
I watched some VOD movie samples on the TVOnline app and did notice a pretty good sound improvement. I'm guessing that the Avov 2 box has a better digital sound processor than the 1. I'm running both boxes through the same Yamaha AV receiver, so that's why I believe Avov improved their box. The VOD picture quality is excellent (1080 for sure).
Please consider that these are thoughts after a very short time with the Avov 2, but I did want to give you all some feedback. Also understand that I have a 1.5Mbps DSL Internet connection. Those of you with better connections may see different results.
I'll post more as I get more testing done.
Does kodi work on it fully?
