I am using KODI STALKER
My order number for Iks66 is: #Staff Edit
My route check is fine shows active and my mac number is assigned, but when I enter http://66.iks66.tv for URL and my MAC number is says
connection refused.
whats wrong ?
connection refused.
whats wrong ?
Keep your order number and MAC address private, please. The order number doesn't figure into the configuration process. I'm not absolutely certain whether you're trying to get IPTV Stalker Plus or PVR Stalker client running, so I'll post links to instructions for both from the Kodi section. Follow the directions explicitly.
IPTV Stalker Plus:
http://iptvtalk.net/showthread.php?1...ow-to-tutorial
PVR Stalker Client:
http://iptvtalk.net/showthread.php?1...et-up-tutorial
Followed the instructions, installed IPTV Stalker PLUS 10.2.4
In Setting selected
Server IPTV66
MAC 3 pairs from the mac email
Login - username and password from email (14 digits)
Password - username and password from email (14 digits)
Selected Send Device Info
Cleard Cache
STILL ACCESS DENIED WHEN I TRY TO RUN IT
There should only be 13 characters in your route number. Did you create the serial number, Device ID and signature as well?
Are you getting an error message? If so, what is it?
From now on, it would be better to post these issues in the Kodi > Video Add-on subforum.
Route number 13 characters sorry (staff edited route number)
Selected Send Device Info, Custom Info Unchecked
error: access denied
You need to configure everything as specified in the instructions (follow it item by item), including the credentials I mentioned previously.
I deleted the route number you had posted,( for your security)... but not before I copied it and checked your code.
I found that your MAC addy has a prefix of 00:1A:79 linked to that route on the iptv66.com website.
For stalker and emulator applications, the prefix should be 00:1A:78
Thanks man. It finally worked !!!
Glad to hear it. The server is unforgiving. It knows what it wants and you have to feed it accordingly.
Good catch, Crazed. I didn't see that. You must have edited it before I read the message.
cool
I bet the tuturial tells all about that thou.
Just saying
And asmirnoff, be aware of what you openly post on these open forums, someone else could have easily copied that route number or Order number from before.
I caught it seconds after you posted it just by chance , is why ilan did not even see it... So please be careful my friend
yes, seconds after it was posted, is why you see no edit notifacation on the bottom of the post either.
Freaky Fast !!
