mag 254 works find with one tv but doesn't work with others .
it says mode not supported. i tried all the resolution. can some one please help both are hd tvs
did you try auto resolution in bios
Ching Ching...And if ur using an hdmi cable, try the rca cable..After, set it up with the hdmi.did you try auto resolution in bios
Mine worka fine with the hdmi. But when i use the rca i get wrong format. How can i fix that? 1 of my tv is old and only takes rca.
Unplug power from the box,then hold the menu button(7th button down on left side of remote)and plug power back in and u should have the bios screen.change resolution to auto,save and exit.Mine worka fine with the hdmi. But when i use the rca i get wrong format. How can i fix that? 1 of my tv is old and only takes rca.
