Hi everyone. I have a few technical question I hope to get and answer to.
First, how do you get a different skin/colour scheme for STB emu? I currently have the blue version but I see some people have a darker/yellow/gold version running. How is this?
Second, does anyone else have issues with the volume? I find that when I am using my STB emu on my android TV, I can no longer control my TV volume. The only volume I see is the STB emu volume bar. For some reason, whenever I run STB emu, my TV volume goes to 35 which is loud, but then in STB emu, even having it at minimum it's still way too loud. Now if I go into the app settings, I can now control the TV volume directly, but as soon as I get back to the channel viewer, the volume goes back up to 33 and I can only control the app volume, not tv.
I hope this makes sense!
Anyone with info?
Thanks!
