Is there any way to have more than 2 portals ?? If so how do we program that mine shows only 2 portals // MAG 254 //
and p
When you get to portals press F1 to add more portals
if you select MULTIPORTAL ON
then PORTAL1 and PORTAL2 are there at PORTAL LOADING SCREEN
you can scroll to add more portals and right there you will be able to to type them
but blanked out in SERVER PORTAL SCREEN as you are now in MULTIPORTAL MODE
THANKS // I FOUND THE WAY
If you have update 0.2.18-r11-254, you can now have up to 8 portals on your Mag254. Hit F1 within the Portals setup and turn Multiportal mode to on. Go to the use portal option and make sure your currently active portals are set to on. Go to portal and scroll to 3 or above (depending on the number of portals you are adding). Turn Use portal (3) to on then scroll down and enter the portal name and URL. Then click ok to save. Hit the menu botton when prompted to access your portals choices when your Mag254 starts to load.....Enjoy
