Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: quality issue
    Apr 2015
    quality issue
    I ordered 3 total mag 254s.. I let my friend get 1 and I got 2.. my friend hooked his up.. and I hooked 1 of mine up..my friend says his quality looks like a dvd player is playing.. mine is the total opposite.. mine is less than 720p.. but my tv is a 1080 smart tv 48 in samsung.. I tried all of the video settings on the mag . And the quality looks like it would If u was to squinch your eyes to watch a normal tv.. any suggestions? I tried all of the video settings even tried switching tvs in my house.. tried rebooting.. now I'm stuck..
    Moderator at Work
    Some channels are not all that good some quite good find most News channels good and the HD i.e. TSN, VEVO some movies like Sony are good but depends on the data they are using.
    Apr 2015
    Ok..they all look great in the small window. But soon as I open up the screen the quality goes bad. Most of the news channels have bad quality.. the better quality channels are mostly the sport channels that I don't watch.. thanks anyway
    Moderator at Work
    Did just check 205 Fox on mag254 and HD version on SV8K and found it hard to see a difference, on 46 inch tv.
    There is nothing wrong with your Mag, all depends on what you feed it to play, thks..
    Apr 2015
    ok.. i havent tried it.. i dont know what sv8k is? ill check out the 205 channel in the morning when i get off work... but almost all of the channels have poor quality.. none have dvd quality but some are better than others
    Apr 2015
    even when i tried switching tvs to a 55 inch it wasnt good quality either.. u can see the grains in the picture.. i was thinking maybe it was a setting that im not aware of..is it certain channels that u know that i shouldnt have an issue with so i could test it?
    Moderator at Work
    Try a different HDMI cable?
    Apr 2015
    When I tried a different tv the hdmi cable was different. . Thanks for the suggestion.. I wish I knew what it suppose to look like so I'll have something to go by..
    Ok first of all where did you buy your mag?
  1. Quality issue
    By supaman32052 in forum Dreamlink T1
    Last Post: 04-01-2017, 12:44 AM
  2. Picture Quality Issue?
    By TVTRAPPER in forum aVOV TVONLINE 4
    Last Post: 08-09-2016, 10:14 PM
  3. Picture Quality Mag 254
    By Ian2 in forum Introduce Yourself
    Last Post: 04-13-2016, 06:09 PM
  4. Top Quality
    By michaeldee in forum IPTV Private Server (IPTV66)
    Last Post: 02-28-2016, 01:11 PM
  5. Pictures Quality
    By blondi in forum IPTV Private Server (Rocket)
    Last Post: 10-03-2015, 01:24 AM
