Ok I'm going try stalker
You have the credentials established. Use those, but make sure you disable IPTV Stalker Plus and IPTV Stalker Simple client before you enable PVR Stalker client. Directions for configuring PVR Stalker client are available in Kodi > PVR Clients (and below).
http://iptvtalk.net/showthread.php?1...et-up-tutorial
Now say me device mismatch what do now
Are you configuring PVR Stalker client or IPTV Stalker Plus? That error occurs more often with IPTV Stalker Plus, although they're both capable of producing it.
If you are getting that error with PVR Stalker client...
Disable PVR Stalker client. Make sure you have both IPTV Stalker Plus and IPTV Simple client disabled. After they are all disabled, and you're certain the configuration is correct in PVR Stalker client, do an IPTV Reset at the donation checker and then re-enable PVR Stalker client.
I do that but nothing happens
By "nothing happens," do you mean you no longer get the error message, or do you mean "nothing has changed" and you still get the error message?
I put my Mac my donation in user and password blank i the address in server I put device id 1 and 2 with 6 digits I uninstalled stalker an disable the PVR I put the 13 number serial and 6 of signature and after reset my route and I wait 15 minutes and nothing happens i have to change my service is the only way I think
Mi channels working perfectly with stalker but the guide no
