Results 1 to 10 of 18
Thread: Hi I need help
    Oct 2016
    Hi I need help
    All my channels no load and I give reset but nothing happens so what i gonna do now help me please
    You need to let us know what device/add-on you are using and what error message, if any, you are receiving?
    Oct 2016
    Hi
    I use a mxq box is android i have 20 megas and I reset my donation but nothing happens thank you for reply my let's me know anything please
    Are you using Kodi? If so, which add-on? You say it does nothing, what does that mean? Is there an error message? Does it try to load, but fails to complete the load? Exactly what happens?
    When you were doing the reset, did you make sure everything was good with your account: active, MAC linked, URL is the same as configured in client?
    Oct 2016
    Thank you again
    Yes does it try to load, but fails to complete the load ⬅⬅⬅thats is exactly my problem
    I'm going to assume you are using Kodi, because I can't get that information out of you.
    Go into System > Settings > TV > General > Click Enable to disable TV then > Clear data (Yes) > then Click Enable to enable TV.
    Give it a minute or two. If it doesn't load, repeat this cycle. After two or three times, it should load, as long as the configuration is correct.
    Every once in a while, it has required a few tire kicks to load at my end, too.
    Oct 2016
    Ok maybe you no understand me ok I use pvr iptv simple client the channels load but no open
    I didn't understand because you didn't specify. You are trying to use IPTV Simple client with IPTV Stalker Plus...is that correct?
    Oct 2016
    Yes I have integrated my donation with iptv simple client
    I had an issue when I tried to use that combination the other day, although it had been working well previously. I haven't researched whether the m3u is being served properly. If you can configure PVR Stalker client for the moment, I'd go that route.
