I'm definitely new to the scene however, I'm able to understand the concepts behind IPTV Rocket configurations in Kodi. I've tried to set up the service on both a PC and android device. So far all I can get working is the Stalker Plus addon for both devices. I am now trying to set up the PVR client on an android device. Here's the problem: After entering all the required fields on the Stalker PVR client and then enabling Live TV on kodi I receive a message that says something about 800 channels found, shortly afterwards I get an Authentication Failed error but the channels /EPG guide still loads the channel list. I've tried both Mac address schemes 00:1A:78 and 00:1A:79. Using the Stalker Plus addon I can only get 79 to Authenticate properly on any device I config. I've currently been assigned to Rocket22 and this seems to have major authentication problems. I'm not stupid and have followed all the directions that have been provided in countless tutorials here and on YouTube. I work as a Network Admin and can promise the issue isn't my knowledge/setup/config... the server hasn't been provisioned correctly! Why else would it work for Stalker Plus but not the PVR client? I've already read others having similar issues with server 22. I wish I would have known of the problems before paying $80 for a years worth of uncertainty. Can someone please advise me on what to do next? I tried contacting IPTV Rocket about a refund if I cant receive a clear picture of what's going on with the service. So far I've heard nothing back which makes me a little suspicious to say the least. Any help would be appreciated! FYI: I already know about the 13 digit serial #, Device ID, MAC resetting etc...
Note: I was able to watch HBO on the Android device using the Stalker Client (00:1A:79) However I'm certain if I reboot the device I will loose Authentication/my channel list and will be forced to reboot, disable/enable/clear/rescan channels in live TV. Each time I restart the device I haft to cross my fingers, and for some reason I usually always get an Authentication Failed error. I have repeated the same steps on a PC but have never gotten the client to work which is strange since the configuration in Stalker are exactly the same. Their must be a better solution then this? If not, can someone tell me how to get a refund other than disputing the charges? Thanks
