Results 1 to 10 of 13
    Yes I do
    Box will not connect with vpn.
    I got a free trial with a vpn company but my avov 4 will not connect to server.i did a speed test . I did a speed test and iget a ping of 60ms and download of o7mbps.tabelts work but box will not connect any ideas.
    Yes I do
    Box fianlly connectednto server but channels won't load is there any settting to try
    You need to do an IPTV Reset. The VPN changes your ip address, so the server won't be happy until you do the IPTV Reset. Remember to close down your device before the reset and to wait a healthy 15 minutes after the reset before firing up the device.
    Yes I do
    Shut down box did iptv reset waited 45min.rebooted router and box will not connect to channels.
    TV Addicted daddyrat50's Avatar
    Quote Originally Posted by 793bob View Post
    In my experience with this service and VPN"S this service is very very picky of which address will work and which won't its a royal pain in the arse. I use a paid vpn and only two or three addresses that this service will work. I tryed another VPN paid service and never could get it to work on that one. I have asked this question numeous times here and never got no answer of why this happens. I would guess no one knows why. If i didnt have the VPN i have now. I wouldnt even be able to use this service.
    Yes I do
    I am trying purevpn.which one do u have.
    tester
    Yes I do
    try ipvanish are cyberghost works the best
    Bullwhale
    if you put the vpn on your router do not reboot your router after you do the iptv reset, you may be changing your ip by rebooting your router
    That is one i use that works, try houston Tx, Atlanta Ga, Miami Fl thats only ones will let mine work. Ip vansish other i tried and for me it was garbage none i tryed worked after numerous IPTV resets and router reboots after changing. I think the key to this is your physical location.
    Quote Originally Posted by duhhud View Post
    i always check my ip address against whats in my router and checking by going to whats my ip
  1. Can not connect /connect failed
    By KingTech in forum IPTV Private Server (Rocket)
    Last Post: 12-11-2017, 03:48 PM
  2. Cannot connect!!
    By Rigo2019 in forum Kodi Tutorials, Tips & Tricks
    Last Post: 07-24-2017, 03:01 PM
  3. can't connect
    By sylvia in forum IPTV Private Server (IPTV66)
    Last Post: 01-02-2017, 01:02 PM
  4. cant connect a 254
    By joeh in forum IPTV Private Server (Rocket)
    Last Post: 12-04-2016, 07:49 PM
  5. can't connect
    By dtvbandit in forum IPTV Private Server (NFPS)
    Last Post: 09-07-2016, 07:08 PM
