Results 1 to 3 of 3
Thread: Sound
    Sound
    Cant hear anything but picture ok I have MAG250 with HDMI connected ..... but when I connect to av there is sound ... need help thank you check tv with other connections HDMI there is sound just d mag ? No sound .....
    try an S/PDIF cable for sound.
    get active
    If you have a Smart Tv or a tv with a menu, go into the audio section of the menu or setup and check to make sure your audio is set to digital not analogue. Your digital cable has to be checked to make sure you have the right type that allows bidirectional audio, if it doesn't, that could be the problem. There are several types of HDMI cables, they are not all the same so check into HDMI cables and if you're not sure what type you're using, buy one that you know will work or ask somebody at a retail outlet.
  1. Replies: 1
    Last Post: 03-25-2024, 01:00 AM
  2. No sound
    By worlok15 in forum Dreamlink T3
    Last Post: 05-22-2019, 07:15 PM
  3. How to get the best sound from my OTT
    By two-dogs in forum OTT M8 4K Android TV Box
    Last Post: 02-11-2017, 04:54 PM
  4. My T1 has no sound ?!
    By montell in forum Dreamlink T1
    Last Post: 05-24-2016, 05:42 AM
  5. HDMI video with no sound/// Cinch cable with sound but no video
    By Dino in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 01-27-2015, 11:03 PM
